Stian_M wrote: The 2 fans are actually the same fan just to have more amps.
If they are driving the same fan, then you need the output configuration set the same.
You have 82 degrees and 85 degrees set in your config across the same fan.
- Shortcar PDM test.png (208.39 KiB) Viewed 190 times
Running the PDM config here on the bench, the fans turn on. As there are no retries configured in the package and the outputs are in effect staged, there is every chance the PDM tried, over current triggered and went into fault.
You would have to check the status of the channel in monitor channels to determine this:
- Shortcar Monitor Channels.png (117.52 KiB) Viewed 190 times
