Edited Post, Lambda reading not showing true value
Postby benntrevv on Tue Apr 16, 2024 8:28 am
Hey guys,
So I’ve edited the post as I’ve figured out most of it.
Im running a link G4X ecu on my evo 8 and the only sensor that I can’t get to show the proper reading in the lambda.
On the link ecu it’s showing 14.2 and on the Motec c125 dash it’s showing 10.2
I’ve tried going into can communications and playing the the add and multiplayer which is what i used to get all my other sensors reading properly but I’m having no luck with the lambda, any ideas as to why it’s reading 10 on the c125 dash when it’s actually reading 14 on the ecu?
Config and dc file attached
Ben
NEW link Dash Config.c125v64
(1.34 MiB) Downloaded 1479 times
New link Dash Display Creator.dcproj
(2.96 MiB) Downloaded 752 times
benntrevv
Re: Link G4X Sensors To C125
Postby Stephen Dean on Tue Apr 16, 2024 10:55 am
Replied to in Support.
Re: Edited Post, Lambda reading not showing true value
Postby benntrevv on Sat Apr 20, 2024 8:45 am
Main posted edited, for some reason I can’t get the lambda to show a true reading?
benntrevv
Postby Anthony on Sun Apr 21, 2024 1:43 am
Can you share the link tune file or at minimum a screenshot of the settings for the lambda can transmit?
Anthony
Postby benntrevv on Sun Apr 21, 2024 11:13 am
Anthony wrote:Can you share the link tune file or at minimum a screenshot of the settings for the lambda can transmit?
I’ve sorted it :)
I had to change the reading on the Motec from lambda to gasoline AFR, and I had to also change the multiplier in can communication for the Chanel down from 1000 to 100.
Ben
benntrevv
Users browsing this forum: Bing [Bot] and 8 guests
