CAN2 RS232 RX mode
CAN2 RS232 RX mode
Postby quadcam on Fri Jan 15, 2021 1:00 pm
If CAN2 of a C1xx dash is to be used to receive an RS232 data stream is there a requirement to translate the signals from RS232 voltage levels to TTL, or does the dash handle that?
I have checked the dash manual and can't see any reference to acceptable signal levels on those pins.
Thanks again.
quadcam
Re: CAN2 RS232 RX mode
Postby Stephen Dean on Fri Jan 15, 2021 3:21 pm
If you are sending an RS232 Serial stream into the Dash, for example from a GPS antenna or ECU, then as long as it is RS232 Serial compliant, then you just need to have the correct baud rate and receive template configured.
Postby quadcam on Fri Jan 15, 2021 5:40 pm
Thanks for the reply.
Yes, it is RS232 Serial compliant from an ECU.
quadcam
Users browsing this forum: No registered users and 24 guests
