Display Creator C127
Postby adminuae on Mon Jan 06, 2020 10:04 pm
Greetings,
I tried to make the next button to change the page but I could not
Kindly help me to make the next button to change the page and reset button to increase and decrease the brightness.
Best Regards,
adminuae
Re: Display Creator C127
Postby rntechnologies on Mon Jan 06, 2020 10:35 pm
Hi Adminuae,
We would need more information in order to assist you with this one.
Can you post a copy of your project?
If not, do you have a physical button wired into the dash that you want to use to change the page, or are you using a CAN based keypad or another device?
If you have a button wired in, you need to setup an Up/Down counter, and transmit this from the dash to display creator. Once this is done, you can create conditions on each of your pages to utilise the counter and display the correct page.
e.g. an up/down counter, triggered by the physical button input, that rolls at the limit called DisplayCounter
Then in each page within display creator, you would have a condition similar to DisplayCounter = 1 for page 1, and so on.
there are many ways to achieve what you are after, this is just one of them.
Regards,
Ryan
Powertune Australia
rntechnologies
Postby adminuae on Tue Jan 07, 2020 1:43 am
rntechnologies wrote:Hi Adminuae,
See the project in the attached.
Yes, I have these buttons.
2030.dcproj
This is a project file
(3.35 MiB) Downloaded 1252 times
adminuae
Postby adminuae on Tue Jan 07, 2020 11:15 pm
Thanks, I have found a way 8-)
adminuae
