C125 Sample DBC file?
Postby CarloL on Sun May 22, 2016 9:56 pm
Hi
I am playing around with the Display creator , I tried to create a DBC file via the C125 Dash Manager demo sample but it requires a device connected to save the DBC file (I do not have any Motec Dash displays)
Would anybody have a sample DBC file in Metric, just want to import it to the Display creator so I can play around with it
thanks
CarloL
Re: C125 Sample DBC file?
Postby David Ferguson on Mon May 23, 2016 3:28 am
While not metric, I think you'll be able to change the units to anything you want, since you'll just be simulating.
Lotus Sport C125.zip
zipped .dbc file from C125 installed in Lotus Sport
(2.06 KiB) Downloaded 1275 times
Postby the_bluester on Mon May 23, 2016 10:02 am
If that does not suit, I can spit out a metric one when I get home.
You should be able to save a DBC file without a display connected though, I did that before I bought my dash.
the_bluester
Postby adrian on Mon May 23, 2016 12:00 pm
The dbc file is created when you save the DM config. You don't need to have a dash connected for this to work.
