Validation Maximum Question
I'm new to M1 Build, so sorry if this question is basic. I'm trying to significantly increase the time constant for the voltage filter of the fuel tank level sensor. I have an old stock fuel level sensor that has a lot of filtering (~30s) in
the stock circuit and am trying to emulate that.
I've adjusted the voltage filter validation maximum to what I want, but keep getting the following error:
Error 1138: "Validation Maximum" must be <= 10 [s].
The "Validation Maximum" on this object must be <= System Maximum 10 [s].
Where is the System Maximum defined? I can't seem to find it. Is there a reason validation maximums are limited to 10s? Is it because of the event rate?
Thank you for any input.
