Driver switch names
Tue Sep 13, 2022 6:25 am
by Mobne
Is there a way to add names to the driver switch, or a note.
I find it easy to forget what a certain switch function have after a while. It would be great if i can add a note to them or change the name of the function so its easy to see what it does.
Re: Driver switch names
Tue Sep 13, 2022 9:47 am
As each Driver Switch can be used with multiple functions simultaneously, this is not an easy change to make as it is difficult to determine which is the primary function that that switch is being used for.
Sat Sep 17, 2022 6:15 am
by Mobne
Can't you still just add a "line" where you can comment it?
To make notes how you once set this up, what its doing and so on. This must be useful to have and can't be that much work to add.
Please do it
Mon Sep 19, 2022 4:32 pm
You can add a "Notes" window into the worksheet that you are using that will allow for these details to be entered, and that will stay with the Firmware on the M1.
Wed Sep 21, 2022 8:44 pm
by Mobne
SDean wrote:You can add a "Notes" window into the worksheet that you are using that will allow for these details to be entered, and that will stay with the Firmware on the M1.
Thanks! Will start using that
