CANComms, Endianess and Bit Offsets
Postby David Ferguson on Tue Feb 09, 2021 9:47 am
Can someone please explain why the "bitoff" parameter passed to the various CANComms.Get<type>() functions does not represent the offset from the start of the buffer when the "bigendian" flag used on the RXOpenStandard() call is false.
I was surprised to find it inverted.
I think of Endianess relating to the byte order of multi-byte quantities, not the bit offset of a buffer. We still call byte offset 0 regardless of endianess, why wouldn't we refer to bit offset 0 as the same?
I wish the M1 Development manual explained this topic in the CANComms library discussion (or even the help in M1 Build for the functions).
Re: CANComms, Endianess and Bit Offsets
Postby adrian on Fri Feb 12, 2021 4:38 pm
We don't really have a proper document on how this works but I have a draft explanation that I use which I have attached.
Let me know if you have any other questions and I'll put it on the list to get added to the help or the Dev Manual.
M1 Build CAN Bit Numbering Intel Motorola.pdf
(317.98 KiB) Downloaded 779 times
Postby David Ferguson on Sat Feb 13, 2021 3:13 am
Thank You!
That is exactly the info I need, and your examples are excellent. I need to add some bitfield stuff to the work I'm doing, and would have certainly been even more confused without this info.
Return to M1 Build
