Help Window's text in M1 Build is invisible
Hello, i am learning how to use the M1 Build, resources to learn are very low, but I am finding the pdfs and help window enough.
Unfortunately the Help Window's text went invisible yesterday, i was using version 01.04.00.0239, it happened randomly without a known cause.
You can copy the text of it, and paste it to see, but its invisible inside the program, the tables,lines and code is visible, but not the texts.
Same goes for the Help window for the Object help, Editing that text results in the same thing, but the xml is visible
I also tried upgrading to 1.4.1.302, same problem.
I'm running windows 10 LTSC 1809
here are a few examples:
Sorry for the long list of images, and thanks a lot!
