M1 development liscence
Postby Giardbusa on Sun Dec 15, 2019 7:51 am
I alreaddy paid for development Licence M130v1.4. Now can I use M1 built to modify myselph some things in my packadge? Or I need other licence?
Giardbusa
Re: M1 development liscence
Postby Stephen Dean on Wed Dec 18, 2019 8:37 am
You should have received two licences with the M1, one being the Firmware Licence that is installed on the M1, and the other being the M1 Build Licence that is used in M1 Build and that the Projects that you create are built against, if you haven't received these licences you need to speak to your MoTeC Dealer to get them both supplied to you.
Once you have these licences installed, then you can build and compile projects in M1 Build, and then send them to your M1 ECU.
Return to M1 Build
