LIN Bus Communication
Hi there
I'm looking for some guidance on implementing LIN in Build. From what I've gathered so far, I think I need:
To send data:
1 - initialise the port using a Serial Port class object (LIN port, LIN protocol)
2 - open a handle (Serial.GetHandle)
3 - set a LIN header (Serial.SetLinHeader)
4 - write some data (Serial.SetUnsignedInteger)
5 - checksum - calculated using Serial.XOR8 - just reading through the LIN spec I don't think this is correct, and that it should be the (inverted) 8-bit sum, which I guess I can achieve using Serial.Sum8 and a bitwise NOT operation
6 - transmit data (Serial.Transmit)
So what I have so far is this:
I don't have an ECU spare to test this at the moment - but does it look roughly correct? Is there anything I'm missing?
Receiving seems a bit trickier, since the ECU will initiate the communication but then needs to listen for the response within the packet. The way I think it should be done is:
1 - open a handle (Serial.GetHandle)
2 - set a LIN header (Serial.SetLinHeader)
3 - transmit header (Serial.Transmit)
4 - receive data (Serial.GetUnsignedInteger)
But I'm not sure if that would be correct or not.
So any guidance, especially example code for sending and receiving, would be greatly appreciated.
To send data:
- Code: Select all
local h1 = Serial.GetHandle(true);
local offset = 0; // this will keep running tally of offset position
local dataOffset = 0; // stores where the data begins for XOR operation
dataOffset = Serial.SetLinHeader(h1, 0, 4, Tx Address, true, false);
offset = Serial.SetUnsignedInteger(h1, dataOffset, 1, data); // send data byte
offset = Serial.SetUnsignedInteger(h1, offset, 1, Serial.XOR8(h1, dataOffset, 4)); // calculate and send checksum
Serial.Transmit(h1, 1, offset);
