Switched Output
Fri Sep 28, 2018 7:09 pm
by gtihk
My next project will involve controlling a switched output according to RPM and throttle position.
Could someone give me a simple guide please?
Re: Switched Output
Sat Sep 29, 2018 3:53 am
Need more detail about the device you are controlling. High-Side, Low-Side, Electrical Current requirement, update rate, etc.
Have you tried looking at similar functions in one of the samples projects to see how its done? What issues to you see with what you want to do?
Re: Switched Output
Sat Sep 29, 2018 12:31 pm
by gtihk
I will need to use high side drive, current will not be high.
It will be used to control a Honda VTEC solenoid.
I was looking at Aux outputs from a GPA package but the contents are greyed out.
Re: Switched Output
Tue Oct 02, 2018 12:23 am
by gtihk
I got it fixed now, by inserting suitable hardware choices.
The output can be controlled by a 3D table.
If I want it to be controlled by several conditions, do I add a built-in Function or something else?
