need to edit an older project (maintenance)
Postby phatbob on Thu Aug 23, 2018 10:58 am
I need to do a maintanance update for a customer in the field using an older project.
The new version of M1 Build wont even let me load the right system (yes, I know its old, yes, I know it may be unsupported), but in the absence of building them a whole new project, how am I supposed to maintain this old code ?!? Its not reasonable to send them a completely new package as the system testing alone would be out of scope, if I just want to make a small change to an older project...
I've only noticed this NOW as I havent had a reason to load the old project until I need to do a small fix...
help ??
phatbob
Re: need to edit an older project (maintenance)
Postby Stephen Dean on Thu Aug 23, 2018 12:33 pm
What is the system that is missing? Is this a v1.3 or v1.4 build?
Postby phatbob on Fri Aug 24, 2018 3:32 am
yes its an older 1.3 system (very old code but its been out there happy as a pig since '15)
should I install an older 1.3 version of build or ??
-P
phatbob
Return to M1 Build
