Keypad Comms
Hi Guys,
I'm just about to attempt direct keypad integration into the M1 using build, however I'm new to the whole CAN side of things though.
So far i have the following:
I dont believe its right though, and i was hoping someone would be able to assist..
I have the list from the racegrade manual in relation to the can specs:
e.g.
Channel, Offset, Length, Bit Mask, Divisor
Button 1, 0, 1, 0x01, 1
Button 2, 0, 1, 0x02, 2
And i also know the can baseID's:
NODE ID = 0A
BUTTON ADDRESS = 0506
LED ADDRESS = 0507
BRIGHTNESS ADDRESS = 0508
I have watched the webinars online, but im confused with the bitmasking side of things.
I was hoping someone that's done it before can point me in the right direction with the CAN stuff.
- Code: Select all
local channel1 = true;
local h = CanComms.RxOpenStandard(0, 0x506, 0x01, true);
local received = CanComms.RxMessage(h);
if (received)
local id = CanComms.GetID(h);
Buttons.Button 1.Channel = id;
if (id eq 0x506)
channel1 = CanComms.GetBit(h, 1);
e.g.
NODE ID = 0A
LED ADDRESS = 0507
