Normalised tracking sensor - scale validation limits
PostPosted: Tue Mar 13, 2018 10:43 am
by MalcolmG
Is there any good reason why the "Normalised Tracking Sensor" module in Build has the validation limits for the Scale locked at +/-100%/V? It would be great to be able to change this (as you can the validation limits for diagnostic high/low and offset). I have a position sensor that changes by less than 1V over it's range so I permanently have an "Invalid Scale" fault.
Re: Normalised tracking sensor - scale validation limits
PostPosted: Wed Mar 14, 2018 10:26 am
by Stephen Dean
Hi Malcolm,
What sort of sensor is it that you are using?
I have to say that I haven't come across a Throttle or Gear Position sensor that has as small a voltage change as the one that you are using, so they have always been within the validation range specified in Build.
PostPosted: Wed Mar 14, 2018 7:23 pm
by MalcolmG
It's just a contactless rotary pot being used to measure the travel of an actuator. It's a quite important actuator on the vehicle which is why we use a dual channel sensor, but the resolution requirements aren't all that onerous so the <1V range from 0-100% isn't a problem
