Pin Current - clearly the ECU is measuring current flow through peak hold injector pins, due to its ability to trigger a fault if the current is too high or reaches a high value too rapidly; from what I can see there doesn't appear to be any way to actually read that value - is it possible somehow? It would be useful for an application I have, where I want to detect whether a pump is pumping liquid or has run dry.
Quick Calibrations - I'm trying to figure out a way to be able to calibrate a sensor both in Tune using the "Q" key function, and when the vehicle is in use and the user gives a specific input (e.g. holding down a "calibrate" button on the dash). Without making turning this into a novel explaining the scenario, here are two questions:
- is it possible to execute a Tuning Method (or modify a parameter somehow) in code, or is it only possible to do from Tune? It looks like Learning Tables essentially allow you to do this, so I could do it with a table with only 1 cell but if possible I'd like to stick with a parameter.
- is it possible to execute an external function from within a Tuning Method? When I have attempted to it compiles fine but throws up an error in Tune when you hit the Q key, I wondered if there might be something I'm missing (I know that Tuning Methods use their own set of functions so I guess there's some sort of operational separation between these and the main program).
Any help would be appreciated
