proper way to set default for CAN channels during no CAN
I have a M1 and it needs to receive a modifier for traction control so I setup a channel to receive it over CAN. But when the device sending that message gets reset or restarted, there is no CAN message and the ECU decides to nullify the value. It actually removes the value and reports nothing other than a CAN diag error. How does one set a default for a sensor input that is receiving data over CAN ? I can't increase the timeout beyond 0.5 seconds because that is hard coded into M1
attached is a picture of the channel inputs I setup as sensors. Is the type "sensor" correct for this?
