Build 1.04 -- Learning Tables
Postby Fast_Moto on Wed Apr 27, 2016 10:39 pm
Is there any example showing the proper use of the learning tables? I saw the explanation of commands for the learning tables in the help section, but the commands do not seem to be useable in a function.
Fast_Moto
Re: Build 1.04 -- Learning Tables
Postby MalcolmG on Fri Apr 29, 2016 3:41 pm
Have you set the "Body Type" of the table to "Learning"? The default is "Tuning" and this doesn't allow you to use the learning functions on the table.
MalcolmG
Postby Fast_Moto on Wed May 04, 2016 12:51 pm
I should be more specific. The help file identifies three ways to adjust a learning table using Set(), Preset() and Adjust(). I can use the first two options, but the last function does not appear to be enabled. Is that right? What am I missing?
Fast_Moto
Return to M1 Build
