Firmware input resources
Postby aNinjaneer on Wed Apr 13, 2016 3:18 am
Is there a way to interact with the Firmware 0-31 input resources? I want to write wheel speeds directly from the OE CAN bus instead of having to use the ECU.Receive like I am now. Are the Firmware inputs reserved only for MoTeC OE modules, or can you interact with them somehow?
aNinjaneer
Re: Firmware input resources
Postby AndrewD on Wed Apr 13, 2016 9:50 am
aNinjaneer wrote:Is there a way to interact with the Firmware 0-31 input resources? I want to write wheel speeds directly from the OE CAN bus instead of having to use the ECU.Receive like I am now. Are the Firmware inputs reserved only for MoTeC OE modules, or can you interact with them somehow?
Yes - this type of integration is exactly the purpose of the firmware resources. The library function to set the resource value is:
Code: Select all
System.SetFirmwareResource()
MoTeC Research Centre
Melbourne, Australia
AndrewD
Postby aNinjaneer on Thu Apr 14, 2016 4:35 am
AH! Thanks, Andrew! :) I searched everywhere for something like that in the documentation, and around the M1 Build environment and couldn't find anything. Good to know!
aNinjaneer
Postby AndrewD on Thu Apr 14, 2016 12:14 pm
We will update the developers manual to fix this oversight.
Regards,
Andrew
AndrewD
Return to M1 Build
