I have been looking through the GPR M150 Package and have a number of questions.
Is everyone ready for a major shift in how we do business in the M1 world.
Questions?
1. Are the GPA and GPR packages going to be expanded or worksheets added for many of the following;
i. For a 2nd or 3rd or etc. PDM.
ii. The display devices (input and outputs), C125 etc.
iii. RS232 GPS.
iv. Light Bars
v. Direct wired Lambda, narrow and wideband (would be nice to use all the points on the ECU
A modular approach will permit everyone add and subtract "stuff" as desired.
2. Will we be able to add workbooks and worksheets to the GPA/GPR packagews for additional equipment noted above? I am not suggesting changes to the GPA/GPR workbooks. Can we create additional workbooks/worksheets and add in with the GPA/GPR packages that could in turn be downloaded to the ECU. Would this have to be done in the Build package or could it be done in the Tune package? I would like to use the GPR package and add to the package and add other devices and additional programmed worksheets.
3. Is there going to be any information on using Lambda devices with the M1? I only found a worksheet in the GPR package for CAN Bus Lambda sensor setup, nothing for direct wired, narrow or wideband. I would expect to be able to use all the input and outputs on the M1 ECU as a minimum with this type of base package.
4. The documentation I have been able to find and read does not address windows file extensions for all files. I am assuming we will need to send the GPA/GPR packages back to the Build software to expand or add worksheets and workbooks. The layout of file types and how to move and open the different file types within the software is needed. It is unclear how the file extension types are made, moved, and handled. A flow chart would be very helpful. This software is going to give companies the opportunity to manage a large number of vehicle types. Some guidelines on package and file management and long term file storage is needed.
5. I thought there was some tire monitoring information collected in the GPR package. Went back could not find such. Maybe it was in one of the GPA packages. Anyway, which 3rd party equipment has these (GPA/GPR) packages been tested with? Race Gear has such an aftermarket package.
