M1 Build v1.4 and v1.4.1
Re: M1 Build v1.4 and v1.4.1
Postby MalcolmG on Tue Oct 12, 2021 8:16 am
FYI it appears you can run multiple installations. I don't know if this is going to cause any problems in future, but I currently have 1.4, 1.4.1 and 1.4.2 all installed on my computer and can run them simultaneously. I've built projects with all versions since having them all installed and haven't noticed any problems so far.
All I did was copy the folders for each older version prior to running the installer, then pasted them back in once the install of the newer version was complete (these are under C:\Program Files (x86)\MoTeC\M1\Build\1.4, C:\Program Files (x86)\MoTeC\M1\Build\1.4.1 and C:\Program Files\MoTeC\M1\Build\1.4.2). I then just made shortcuts to each M1Build.exe file on the desktop and named them appropriately.
MalcolmG
Postby Stephen Dean on Tue Oct 12, 2021 2:24 pm
Also, as 1.4.2 is a 64 bit program, it is installed in a different directory structure (Program Files) to 1.4.1 and earlier (Program Files x86) so 1.4.2 and the earlier ones can coexist.
Return to M1 Build
