CanComms.RxOpenStandard still can't accept variable bus #
Re: CanComms.RxOpenStandard still can't accept variable bus
Postby Gaston on Sat Nov 10, 2018 12:52 am
Thanks a Lot !!! :oops: :oops: :oops: :oops: ;) ;) ;)
Gaston Scazzuso
whatsapp: +54(9)11 5385 1996
mail: soporte@moteclatinoamerica.com
Gaston
Postby MalcolmG on Tue Dec 04, 2018 3:48 pm
DarrenR wrote:
Code: Select all
local h = CanComms.RxOpenStandardBuffered(0, 0x100, 0xF, true);
local canID = 0x105;
if (CanComms.RxFindMessage(h, canID, 0, 0, 0))        //finds the newest message with id 0x105 (set in by the local).
                Channel = CanComm.GetUnsignedInteger(h, 16, 16);
FYI it looks like this line:
Code: Select all
actually needs to be like this for it to validate:
Code: Select all
if (CanComms.RxFindMessage(h, canID, 0, 0, 0x0))
MalcolmG
Postby DarrenR on Fri Jan 25, 2019 4:11 pm
MalcolmG wrote:
DarrenR wrote:
Code: Select all
Code: Select all
Code: Select all
You are correct, the argument is an unsigned integer so needs to be written in hex - 0x... My mistake.
Thanks!
Darren Reynolds
DarrenR
Return to M1 Build
