A follow up question, Andrew, relating to my prior inquiry about resource assignment and polarity. In the tuning worksheet in the GPR package, there are maps for exhaust camshaft aim retard and inlet camshaft aim advance. Am I correct to assume that when the second actuator output for each cam is assigned and in use, the tuning maps for camshaft control automatically use the correct actuator output for retarding or advancing each cam? If so, how does the code know which actuator output is being used for retard and which for advance? The only way it would seem to work is if each actuator is hard-coded to a particular function. E.g., actuator output 1 for intake camshaft is advance and actuator output 2 for intake camshaft is retard. And if THAT is the case (which it seems it must be), then which actuator output serves which function for each camshaft? Help!
--Peter
