Hi there
I'm hoping for some clarification on where you can and can't use Peak Hold Injector outputs as general purpose outputs. I have a project where I am trying to run a small pump from a PH output, but if I leave the resource as a parameter then the PH outputs don't appear in the drop down menu in Tune, and if I set it as a constant in build I can choose a PH output but when I attempt to validate it I get the error that the PH output is not allowed for the associated IO method (the method being a PWM output).
This seems to contradict the built in modules for Coolant Fans which look like they use a the same PWM IO method and there is no issue using PH outputs for those
Am I missing something? Is there a clear rule for what PH outputs can and can't be used for?
Thanks,
Malcolm
