TunedByShaneT wrote:maybe not possible to do but would really be helpful to be able to simulate the build using software to make sure it has the expected behavior. Right now I can do it by sending the build to tune and loading it into an ECU on the simulator which ultimately you would want to do anyway but I was thinking it could be very beneficial if it could be simulated ahead of time or if you wanted to build a package for an ECU you didn't happen to have in stock. Maybe once you have a good proficiency with Build - this would not be needed as much but seems like a good idea now.
