Dialing in fuel film
I have the acceleration working decently, I still see a short lean spike and then rich but the motor feels good so I think I'll leave it. It doesn't seem like there's really a way to remove both, I can get the lean spike smaller but then it will go even richer.
Now, deceleration I have not tried to setup yet but looking at the logs I'm not quite sure how to go about it. It goes rich first and then very lean for long enough that the RPM drops below idle temporarily. If I reduce "fast decrease time constant", if I understand this correctly, it would reduce fuel faster which would remove the initial rich spike but the lean spike is just 0.3s after that so that would probably get even worse?
What's the correct approach to correct his? Attached is a screen shot.
