Water Pump
Water Pump
Postby mdn-t on Thu Jun 04, 2026 4:47 am
Hi. Can you tell me if you can control the water pump directly from the M1 using the Half Bridge (Drive "Low Side") output? Pump Davies Craig EWP150. Current consumption 10. 5 amperes. Plus, the pump is fed with PDM.
mdn-t
Re: Water Pump
Postby Stephen Dean on Thu Jun 04, 2026 5:44 pm
From experience, it is better to use the PDM as the power supply for the EWP, and use the Davies Craig controller to do the control of the pump.
