M1 Tune 1.5 feedback
PostPosted: Thu Nov 14, 2024 9:01 am
by greenamex2
Not used in anger but ...
Like the new look and features.
Really infuriating seemingly not being able to add to "favourites".
The touchscreen additions are exactly what I envisioned when I mentioned tablet compatibility some years ago. Just add the keypad and extend to other inputs (my car has a touchscreen and PC built in so vested interested).
Would love the option to select the start up a specified "workspace after connecting to the ECU, for instance Monitor -> Dash. Again, vested interest with the in car PC and 12" touch screen monitor.
Re: M1 Tune 1.5 feedback
PostPosted: Thu Nov 14, 2024 9:26 am
by NathanB
Adjust editing.png (41.94 KiB) Viewed 20548 times
In options you need to turn on Enable adjust group editing.
Then you will have the settings gear appear
Adjust group editing 2.png (21.39 KiB) Viewed 20548 times
At the bottom of this screen, you can change your favourites.
Adjust group editing 3.png (15.01 KiB) Viewed 20548 times
This was covered on page 32 of the user guide that was also provided for download.
PostPosted: Thu Nov 14, 2024 6:59 pm
by greenamex2
Awesome, will have a play tonight.
PostPosted: Fri Nov 15, 2024 8:56 am
by greenamex2
That is pretty neat, especially for those of on the Multi Throttle Body tuning method using the Inlet Manifold Pressure Estimate Main table I can never remember about!
PostPosted: Fri Nov 22, 2024 1:38 am
by Thezedhed
I've only just started using Motec M1 tune (1.4) and so just getting to grips with resource assigning.
Loving the new look and pin out pictorial, very handy.
Is there a way to edit the I/O resources names that you pick from or add a note so I know what they actually are?
For example I'm wanting an I/O's for an Accusump pressure sensor and solenoid but can't find anything meaningful.
I have an excel spreadsheet listing what they are but didn't want to be complicating things if there was a better way.
Thanks in advance
PostPosted: Fri Nov 22, 2024 8:36 am
by SOReilly
Thezedhed wrote:I've only just started using Motec M1 tune (1.4) and so just getting to grips with resource assigning.
Thanks in advance
M1 Tune doesn't have any name aliasing. If you are logging a channel and want the name to appear differently for analysis i2 allows you to alias a channel
PostPosted: Fri Nov 22, 2024 9:03 am
by Thezedhed
Thanks for the reply SOReilly,
At least I know I'm not missing something or doing it wrong :D
PostPosted: Mon Sep 08, 2025 3:05 am
by Suprafied
Is there an option to hide all of the dials that are available to adjust functions?
PostPosted: Mon Sep 08, 2025 4:33 pm
by SOReilly
Hi Suprafied,
In the top menu bar open Tools>Options, on the applications tab at the bottom you can disable all the touch controls.
