OMP M130 GPR rotary package
I have a 6 pin OMP for my Mazda RX7-13B-T and I am trying to connect it to the ECU. However, I need 4 halfbridge outputs for the two motors and I can only connect to two Ressource (A and B).
From documentation I have found that:
- OUT_HB1 : Bridge 1 +
- OUT_HB2 : Bridge 1 -
- OUT_HB3 : Bridge 2 -
- OUT_HB4 : Bridge 2 +
- OUT_HB5 : Bridge 3 -
- OUT_HB6 : Bridge 3 +
I was then wondering if the halbridge positive and negative pins are internally connected and I just have to put un Ressource A and B one of the two pins ?
For example : Ressource A set to OUT_HB2 (then also connected to OUT_HB1 ?) and Ressource B set to OUT_HB3 (then also connect to OUT_HB4 ?)
Thank you for your time !
