Injector Change and Fuel table Maxed
Hi All
Couple of Questions
Background Info
Mazda RX7 ..12A turbo Engine
2x 850 Cc Primary and 2x 1600 Cc Secondary Injectors
Q1.
Swapped from 1000 Cc Bosch "040'" to Siemens 850Cc for better Idle control (which i got )
After change over and resetting the injectors to the correct setting in the software the car runs perfectly
it seems the software adjusted for the smaller injector without remapping the fuel table ?
Is this correct ?
Q2.
I'm close to 300 (292) in the fuel table at the max boost we want to run
injectors staged at 30/70
but the duty Cycles are low 55% primary and 68% secondary
is this normal when my Fuel is near Max ??
John P
Couple of Questions
Background Info
Q1.
Is this correct ?
Q2.
John P
