How to turn Huracan Ignition table to inlet pressure?
Postby TurboTim on Sun Feb 04, 2024 9:21 am
I was easily able to turn the fuel table to inlet pressure but I can't figure out how to get the ignition table to be setup with inlet pressure instead of load, where is this located?
TurboTim
Re: How to turn Huracan Ignition table to inlet pressure?
Postby NathanB on Mon Feb 05, 2024 8:18 am
The efficiency table (fuelling) is inlet manifold pressure by default, so I'm not too sure what you think you changed.
The axis of the ignition timing will always ready engine load normalised, but under Initial Setup > Engine details, you have the ability to define how that is calculated. It can either be against throttle, inlet manifold pressure or 'normal'. When set to inlet manifold pressure, the engine load is inlet manifold pressure / 101.325kpa. This (depending on ambient pressure) effectively works out to 100% = 100kpa, 200% = 200kpa etc
Postby TurboTim on Mon Feb 05, 2024 8:30 am
Okay so that makes sense what I changed then. I will properly scale my Ignition table now. Thanks for the response!
TurboTim
