M130 GPLite map switch
Mon Jan 01, 2024 3:45 pm
by Alwayslearning
Anyone familiar with the GPLite ECU? I'm wondering if I can use an ethanol content sensor on pin B6 which is pre-assigned as Map Switch?
Re: M130 GPLite map switch
Tue Jan 02, 2024 9:34 am
Pin B6 on the M130 is an Analogue Temperature (AT4) input, this is not the type of input that will recognise the digital signal from the Ethenaol Content sensor.
Tue Jan 02, 2024 8:06 pm
by greenamex2
You would need to use a "UDIG" pin, so B8/9/10/11/14
