Driver Pt / Pit Speed Switch help
PostPosted: Tue Nov 28, 2023 6:53 am
by greenamex2
Is the help for Driver Pit and Driver Pit Speed Switch mixed up?
The Pit Speed Switch help refers to a 10 position switch but has no position/mapping options where as the Pit help refers to it being on/off but DOES have position/mapping options.
Screenshot 2023-11-27 194444.png (400.46 KiB) Viewed 5296 times
Re: Driver Pt / Pit Speed Switch help
PostPosted: Tue Nov 28, 2023 8:53 am
by SOReilly
Current release GP based packages refer to the Pit Switch as an On/Off switch and the Pit Speed Switch is multi position.
Pit Switch enables the Vehicle Speed Limit Pit subsystem and Pit Speed Switch provides a table axis to change the Vehicle Speed Limit Pit parameter value.
Are you using an older firmware?
PostPosted: Tue Nov 28, 2023 9:53 pm
by greenamex2
GPA 01.11.0159
PostPosted: Wed Nov 29, 2023 12:46 am
by David Ferguson
Both Driver Pit buttons will accept a Driver Rotary Switch. You only need mapping on the Pit Switch since it's the only one that needs mapping to an on/off state depending on the multi-position value. The Driver Pit Speed Switch is used as an axis for the "Vehicle Speed Limit Pit" table, if an on/off switch is used here, only the 0 and 1 positions are used.
I can see how that's confusing, but read the help for each one with the above in mind, and I think you will see it's working correctly in GPA 1.11.0159
PostPosted: Wed Nov 29, 2023 1:17 am
by greenamex2
David Ferguson wrote:Both Driver Pit buttons will accept a Driver Rotary Switch. You only need mapping on the Pit Switch since it's the only one that needs mapping to an on/off state depending on the multi-position value. The Driver Pit Speed Switch is used as an axis for the "Vehicle Speed Limit Pit" table, if an on/off switch is used here, only the 0 and 1 positions are used.
Reading "the "Pit Switch" help with your supplement makes a lot more sense, thanks.
The "Pit Speed Switch" help could do with some simplifying!
Thanks for clarifying David
PostPosted: Wed Nov 29, 2023 8:48 am
by Stephen Dean
The operation of the driver switches is being investigated for functionality changes in the next major release of the GP Packages.
PostPosted: Wed Nov 29, 2023 9:10 am
by greenamex2
Stephen Dean wrote:The operation of the driver switches is being investigated for functionality changes in the next major release of the GP Packages.
Makes sense...looking forward to more toys!
