GPRP Pro M150 01.06.0552 Nitrous Activate / Reset
we are trying to activate a 100 HP Dry Shot Nitrous Direct Port system to assist in Pre Spool a big turbo on a 4g63 evo 8 engine.
out plan is to activate the nitrous from 2750 Rpm until 5750 (off boost) to improve the power band.
the problem is that it seems the ( Nitrous Reset Engine Speed) doesn't seems to work for some reason.
we enabled the mode and we set a window of 3000 rpm Min, 5750 rpm Max. assuming that the reset will be enable above 5750 rpm to stop the nitrous (transition to enable), but this is simply is not happening!
is there a contradiction if the (Nitrous Active Engine Speed) is enabled, while the (Nitrous Reset Engine Speed) is disabled !
