Closed loop fueling
while on the dyno configuring the VVT I experienced that the closed loop fueling hit the maximum enrichment level set (15%) and then after a few seconds disabled the closed loop fueling with the result the AFR went lean.
Is this a normal behaviour or is it possible to configure the closed loop to continue at maximum enrichment even if it doesn't reach the AFR aim value?
Another question, is it possible to configure closed loop fueling to be active only in parts of the engine load / MAP axis? ie. turn it of at WOT.
