CAN Switch Setup
I'm looing for some help to setup a switch via CAN to toggle 2 different drive modes in an M1.
The switch sends a voltage signal to my AEM Dash (via AV Input) so the Dash can send a CAN message to the M130.
Switch to Dash
Steady Signal - 1.27v
Drive Mode (when button is pushed) - 4.98v
I setup the AEM dash to transmit the AV signal via CAN on ID 0x7F0 at 2 Hz Length 8 Position 0 (image attached).
I can see the AEM is transmitting the CAN message with a CAN Interpreter (image attached).
I setup the M1 resource as CAN 0 Offset 0 (image attached).
I have played with the switch setting but can't get the M1 to respond to the change. What am I doing wrong?
Switch to Dash
