Rotary setup and tune
I have an Mazda 20B rotary with ITB´s and peripheral ported with an supercharger. There is an Map sensor after the ITB´s do I need an boost sensor before also?
What is the right way to setup and tune that?
I have tried to follow the CTN0036 guide but I cant find the boost and Engine Efficiency Airbox
compensation table
Engine efficiency mode: Manifold Air Density
Engine Load Normalised: Throttle
Inlet manifold Pressure: Estimate
Inlet Manifold Pressure Estimate: Boost Pressure Relative
M130 GPR Rotary Throttle based start file v14
https://moteconline.motec.com.au/Packag ... ed%3DFalse
compensation table
