It will work anywhere providing the all the influencing channels are set up correctly, and I have tuned many cars using this method. The V8 supercars in Australia are also tuned and run on this method.
- Map estimate tuning.jpg (663.46 KiB) Viewed 7988 times
The MAP estimate tuning method for individual throttle bodies or applications where a MAP sensor is not utilised is a lot less forgiving on anything set incorrectly compared to when a MAP sensor is used. If any of the following items are set incorrectly you can have bit issues with the calculations:
- Engine Displacement
- Engine efficiency mode
- Engine load normalised mode
- Fuel properties
- Injector location
- Fuel injection timing
- Inlet manifold pressure mode
- Inlet Pressure estimate mode
- Airbox/Ambient pressure sensor calibrations
- Fuel pressure sensor calibration, estimate or regulator setup
- Any fuel volume trims or compensations active
- Incorrectly tuned or setup fuel film
- Efficiency table not set to 100%
- Not enough resolution in the estimate table in the area of tuning
- Not being well centred on a load site/crosshairs when using quick calibrate
- Incorrectly set cooling charge gain
- Using quick calibrate in a transient instead of a relatively steady state condition
- Injectors resources assigned wrong
- Firing order set wrong
- Wrong injector calibrations
- Fuel mixture aim set wrong
- Active fuel mixture aim table is not the main, so target lambda is incorrect
The complete fuel calculations tab under 7. Monitor > 4. Complete fuel calculations can give some great indications of any potential issues in a calibration, or if a trim/comp is set wrong.
There are so many possibilities that could cause the issue it is possible to do more than speculate at least without a config, and ideally logging. Also be aware that not all custom firmware/partner packages will necessarily support the map estimate tuning method.
