Cannot Send packages after latest System update
Hi all,
The latest .0095 System seems to be causing some major issues for me. When I initially tried to update the System, it immediatelty failed with the error message "Failed to Login to the ECU". Ever since then, I cannot Send any packages to the ECU, update Security permissions, update System, etc. This is happening now on two different ECUs, both in vehicle and on test bench, and on two different laptops. I have also tried the Ctrl + Alt "Force Send" method with the same result. I AM able to make online changes and save them, run the engine, etc. I am having a few other new firmware bugs now as well, but since I can't revert to an older Package, I cannot test this either.
I can't seem to find a way to revert to an older system. I'm not clear on the function of "Override ECU System Version" option but that hasn't seemed to help regardless. Is this a known issue?
