CAPTURE INPUT FAILIURE
Postby GWRMOTORSPORT on Mon Aug 30, 2021 10:09 am
Hi
had an issue this week with M130 GPA, June 2019 package, lastest tune updates.
Engine was nothing special, V8 multi tooth ref, single tooth sync, single CDi, ITB's
With the engine running when I tried to get a capture inputs trace I get a
'Failed capture' notification box, still had comms with ECU.
The power was cycled and a capture was available under cranking with
engine run switch off, tried again with the engine running and I got the same result
of 'Failed capture'
any ideas, thoughts
GWR Motorsport
GWRMOTORSPORT
Re: CAPTURE INPUT FAILIURE
Postby Stephen Dean on Tue Aug 31, 2021 2:16 pm
This sounds like there might be some interference coming into the signals from the crank/sync, most likely from the CDI. When the engine is running do you get any errors reported in the Reference and Sync diagnostics?
Postby GWRMOTORSPORT on Mon Sep 06, 2021 8:38 am
Hi
so had the same problem with ref sync capture in M1,
This time using a different laptop, different ethernet lead and on a MoTeC PNP Hurracan kit.
Situation, ECU powered up, engine not running,tried to do a 'capture inputs' and it came up
with the same error as previous engine.
The error comes up with something about incorrect package sequence.
I will try and record a screen shot and the ecu messages to help.
Steve
GWR Motorsport
GWRMOTORSPORT
