Start & Com Problems.
Hi All, Thank you for taking a look at this post!
I just recently tried to connect my laptop with M1 Tune software to my 2004 Hayabusa with a MoTec M130 ECU and C127 Display.
I started my computer and M1 tune with no problems. I use a USB to Ethernet connector and ethernet cord to attach to my ECU using MoTec's Ethernet connector. I have never had any connection problems with this set up. I turned on my ignition to my bike and the headlights turned on and my electric fuel began to prime. Normally, the fuel pump primes then shuts off. I can't remember if it is a time delay or fuel pressure that signals the shut off? The C127 display never turned on or even flickered to do its MoTec start up ceremony. The bike will engage the starter but, the engine will not start. Seems like no ignition spark. The M1 Tune program does not show any ECU. These problems happen whether I have the Laptop hooked up or not. My thoughts are that the ECU is not getting power or it is fried.
My questions are:
What is the logic of the interplay between the ECU and display? Does the ECU have to be powered for the Display to start-up?
I am not sure what shuts off the fuel prime, Pressure or time?
Is there any fuel system start-up logic for triggering ignition to begin?
Supposing the electrical connections to the ECU are good, what could cause the ECU not to receive power?, are there some built in logic safeguards?
Here is a link to the Vid showing the problems:
https://drive.google.com/file/d/1o6tUDg ... sp=sharing
Your thoughts:
Thank You for your time and thought with this!
Jack
My questions are:
Your thoughts:
Jack
