Saving Telemetry Data
Sat Mar 06, 2021 10:35 pm
by kangsta
Hoping someone can set me straight... I've looked everywhere for an option to save the live telemetry data when connected to an ECU. Surely there is an option somewhere that Ive missed?
Re: Saving Telemetry Data
Sun Mar 07, 2021 3:42 am
by David Ferguson
No, you can only saved the logged data.
Now you can hit the "pause" button and scroll back to see all the data in the current session, but there is no "save live data" so that it can be shared, or studied later.
Sun Mar 07, 2021 9:11 am
by kangsta
David Ferguson wrote:No, you can only saved the logged data.
Thanks for the confirmation. I guess you can only open logged files in i2 as well and not in M1 tune?
Sun Mar 07, 2021 9:54 am
by David Ferguson
kangsta wrote:Thanks for the confirmation. I guess you can only open logged files in i2 as well and not in M1 tune?
correct.
Wed Mar 10, 2021 11:16 am
by Stephen Dean
If you are connected to the M1 then the data is constantly being updated (even when paused), however, if you want to be able to go back over the data without the risk of it being overwritten, disconnect from the M1. The live data stops updating and what data is available in the live graphs will remain there until you next connect to the M1, or close M1 Tune. This becomes useful if you want to go back and analyse issues in the live data as you have access to all of the channels that are being generated in the M1 at a 50hz log rate.
Sat Jun 26, 2021 11:39 am
by kangsta
SDean wrote:If you are connected to the M1 then the data is constantly being updated (even when paused), however, if you want to be able to go back over the data without the risk of it being overwritten, disconnect from the M1. The live data stops updating and what data is available in the live graphs will remain there until you next connect to the M1, or close M1 Tune. This becomes useful if you want to go back and analyse issues in the live data as you have access to all of the channels that are being generated in the M1 at a 50hz log rate.
Good tip - Thanks
