PWM SSD3 setup on M150
I am trying to set up a SSD3 with a Weldon 2345a fuel pump. The question I have is the wiring of the two input wires on channel 1. If you've wired this up and gets it to work, can you confirm how you wired up the two input wires? I find it confusing how they explain the low and the high current on the device itself vs. the printed documentation. Also, what frequency would be good to run it at. See attached.
