Oscillations in lambda values above 2000 RPM
I am trying to run the Royal Enfield Classic 500 cc single cylinder two - wheeler engine using an M150 ECU. Currently, I am tuning the VE Table from scratch using lambda values from a wide band LSU 4.9. I have done some calibrations of the VE Table up to 2000 RPM and have faced no major issues as such. But above 2000 RPM, there are severe oscillations (from .8 to about 1.2) in the Lambda Values and I am unable to figure out the reason. I have turned the closed loop fuel off. I know that there is something wrong with the fuel system, some incorrect timing or fuel film is not right, but I don't know the exact reason.
A snip of the telemetry display of fluctuations is attached in the following link:
https://drive.google.com/file/d/1X-DAR3eJv4Mmr7SCLQm-k3dc7uao0fgp/view?usp=sharing
Has anybody ever experienced a similar issue? Any suggestion would be much appreciated.
Thanks & regards,
Sagar
Thanks & regards,
Sagar
