Too much fluctuations in the MAP sensor values
I am using a Manifold Air Pressure sensor for intake air density determination to fire a Royal Enfield 500cc single-cylinder engine using the M150 ECU. As we know, we have no option (like throttle %) other than the intake pressure value for the load axis in the engine efficiency table. With the engine running, the intake pressure values are fluctuating too much ( from about 50 kPa to 100 kPa at 900 RPM and 15% throttle), and I am unable to target the cursor to a specific cell in the engine efficiency table, and each time I press the space bar (to get to the current operating point), I get a different cell (between 50 kPa to 100 kPa). It is natural to fluctuate since it actually fluctuates due to the opening and closing of the valves.
I know a method by which I can motor the engine at different speed & throttle conditions to fill up the pressure sensor estimate table and then use the table. But won't that also fluctuate, since it takes the current value of MAP sensor each time I press Q and the value is itself fluctuating? Can I use filters to reduce the fluctuations and get an average value? Also, is there any other method by which this can be done?
Thanks & regards,
Sagar
Thanks & regards,
Sagar
