Driver switch CAN
Hello guys,
Question regarding driver switch input. Lets say we have the input ressource via CAN.
CAN 0 offset 0
CAN 0 offset 2
CAN 0 offset 4
CAN 0 offset 6
I have my keypad buttons configured into my PDM (Message 0 with channels from 0 to 7) to send the activation to the M1. No I am not using the keypad directly with the M1.
The only time my driver switch status will activate is if I select offset ''2'' or ''4'' and use channel ''2'' or ''4''. Those are the only offsets I can activate my driver switch from toggling ''On'' or ''Off'' my keypad. The input voltage goes to 0.256V. If I choose to use lets say my channel ''0'' from my PDM, and use offset 0, it only changes from ''0'' to ''1mV''.
If I select offset 2 for example (and change my button to Channel 2 in PDM manager), it works.
And is there a way to see more than just 0.256V ?
Thanks for your help, I suck at this.
CAN 0 offset 0
CAN 0 offset 2
CAN 0 offset 4
CAN 0 offset 6
