Engine Speed Pin Rejected Pulse
Postby rayhall on Sun Jan 26, 2020 5:53 pm
I have a m150 in a Audi v10. At 2000 rpm I get a misfire . It is not load related . The data log shows Rejected Engine Speed Pulses.
Should this be a threshold voltage setting or something like Engine Speed reference Blank Ratio.
Ray.
rayhall
Re: Engine Speed Pin Rejected Pulse
Postby rntechnologies on Tue Jan 28, 2020 7:44 am
If you are getting the message identifying rejected pulse, you need to check your hysteresis setting. (That is if you have the correct threshold set).
Hold the vehicle at 2k rpm and do an input capture. From there you should be able to correctly set your ref/sync settings.
Also, if the trigger is noisy for any reason, it can be normal to see rejected pulse as a diagnostic.
This diagnostic is simply indicating that a pulse has not met your criteria in order to be accepted.
Regards,
Ryan
Powertune Australia
rntechnologies
Postby rayhall on Sun Feb 02, 2020 7:36 pm
The hysteresis settings were correct. The problem was solved by changing the Engine Speed Reference Narrow Pitch Threshold [%] from 50% to 60%. Now smooth as a baby's bum.
Ray.
rayhall
