Cant export package from M1 tune
Postby Donovan CR6 on Thu Oct 03, 2019 6:04 pm
For some reason I cant export a package from M1 tune , I click on the tab and nothing happens.
Anyone else experience this?
Donovan CR6
Re: Cant export package from M1 tune
Postby Stephen Dean on Fri Oct 04, 2019 10:15 am
HI,
What Package are you trying to export? What version of M1 Tune?
Are you going File | Export As... and it is failing to proceed from that point on?
Postby Donovan CR6 on Fri Oct 04, 2019 7:49 pm
So I made changes to timing and fueling maps, saved as a new package, click export as and nothing happens. Also tried to do it in the ''open package page'' still nothing happens.
Its the new version 1.4.0.246
Donovan CR6
Postby David Ferguson on Sat Oct 05, 2019 9:47 am
I am using 1.4.0.246 and have no issues exporting on Windows 7 Home Premium - 64bit. When I use File->Export As... I get the normal file save dialog. Any chance you have two monitors and the dialog is appearing on another screen, or you've enabled a projector (which looks like another screen).
Postby Stephen Dean on Mon Oct 07, 2019 10:16 am
Along the lines of what David asked, when you go through the export process, can you keep working in M1 Tune after this, or does the program hang? If it is hanging then is sounds like the dialog window is opening on a different "screen" and isn't visible, Can you try pressing the Esc key if this happens and see if that restores operation back to M1 Tune. If you can keep working in M1 Tune then something else is going on.
Do you have any other MoTeC Products installed on your computer?
Can you install M1 archives?
Postby Donovan CR6 on Mon Oct 07, 2019 5:38 pm
yes I can still work on everything, nothing is hanging. I'm only using my laptop screen no other screen is connected.
With window 10 Pro 64
Yes and I've got most of the other Motec software installed and I can install archives.
:? Thanks
Donovan CR6
Postby Stephen Dean on Tue Oct 08, 2019 12:13 pm
When you start M1 Tune, do you get a script error pop up?
If you do, can you go to Help|Repair... and run the repair process (do this in M1 Build if that is installed as well) and then retry to Export a Package.
Postby Donovan CR6 on Thu Oct 17, 2019 12:37 am
There is no error , I tried to repair still but no luck :(
Donovan CR6
