PSI/g to KPA/g
Sun May 26, 2019 2:56 pm
by rayhall
The boost control settings are set to PSI gauge and I would prefer KPA gauge. How can I change this.
Ray.
Re: PSI/g to KPA/g
Mon May 27, 2019 3:55 am
by David Ferguson
There are a couple of ways to do this in M1 Tune. I normally fix them as a go along, so when you see a channel or parameter you wish to change, right click on the item, and choose Active Item->Properties, where you can set the display units, # of decimal points, etc.
Another way, is to use Tools->Show Data Properties... This shows all data Parameters and Channels. You can select one or more channels and use the Edit button to change properties they have in common. Double-clicking edits just the selected item.
