Cuts in logged data
Cuts in logged data
Postby Shivshankar on Wed May 08, 2019 10:59 am
I am from an Formula sae team and we run M150.
Could anyone shed light on why cuts maybe found in logged data?
Is it an electrical problem?
Shiv
Data cuts.jpg (434.47 KiB) Viewed 8384 times
Shivshankar
Re: Cuts in logged data
Postby Stephen Dean on Wed May 08, 2019 11:15 am
Usually this is caused by the ECU CPU load increasing and the M1 prioritising the running of the engine over the logging, can you log the CPU usage and see what it is doing at that point.
Postby Shivshankar on Wed May 08, 2019 11:37 am
Below is the screen shot of the cpu usage
cpu usage.jpg (589.39 KiB) Viewed 8381 times
Shivshankar
Postby Stephen Dean on Wed May 08, 2019 5:19 pm
Can you send the log file through to support @ motec.com.au thanks.
